It is currently Fri Aug 22, 2025 11:51 am
PostPosted: Fri May 17, 2013 3:00 pm
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
Hey all,
This one was finished out of order. I had it almost done about 18 months ago, but while I was doing the final polish, I sanded through the finish in one spot. That took the wind out of my sails a bit, so I re-coated the offending area and set it aside.
Then last week decided it was time to finish it. I very carefully sanded the lacquer level again in that spot, and almost sanded through again. But it’s not too noticeable, and anyway, I’m done. :D I buffed it up, glued on the bridge and neck, and strung it up.
This is the third 12 string acoustic I’ve made, and I tried a few new things. I used the shared-pin method, where the bridge only has 6 pins, with two strings per pin. (Thanks to whoever did the tutorial on that!) And I compensated the saddle, which should always be done anyway of course, but I just didn’t bother with the other two. I also put two carbon fiber bars in the neck.
I used Arizona desert ironwood for the bridge, fretboard, and head stock veneer. The bindings are curly maple. The rosette is osage orange and abalone. The top purflings are abalone also. The top is lutz spruce from Shane, and the back and sides are osage orange from the county south of me. The action needs some more work, but it sounds great! I also need to make a cover for the truss rod access slot, and I need to level the frets.
Some pictures:
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Fri May 17, 2013 3:01 pm
First name: Phillip
Last Name: Patton
City: Yoder
Regards,
Phillip Patton
PostPosted: Fri May 17, 2013 3:17 pm
State: Tennessee
Nice guitar, that Osage Orange is spectacular.
PostPosted: Fri May 17, 2013 3:23 pm
Man.... I wanna build with Osage Orange, too.
Very nice guitar, well done!
PostPosted: Fri May 17, 2013 7:55 pm
First name: Tony
Last Name: C
City: Brooklyn
Beautiful job! I also like the bridge treatment. Well done!
http://www.CostaGuitars.com
PMoMC
PostPosted: Fri May 17, 2013 9:00 pm
First name: Larry
Last Name: Hawes
So unique in so many good ways. Nice, nice job.
Thank You and Best To All
PostPosted: Sat May 18, 2013 9:50 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Very nice....lots of glamour there :)
PostPosted: Sat May 18, 2013 10:28 pm
That's really nice, way to go!
You should do Damascus steel frets on your next one! :)
PostPosted: Sat May 18, 2013 11:02 pm
First name: Garett
Last Name: Dixon
State: WY
+1 :D
PostPosted: Mon May 20, 2013 9:06 am
First name: Coe
Last Name: Franklin
City: Decatur
Looks great, Phillip!
I`m looking forward to using my set of Osage Orange.
Did you do anything to reinforce the bridgeplate to accomodate for the ball-end pressure being pretty much in line?
I`m just curious.
Coe Franklin
PostPosted: Sat May 25, 2013 11:41 am
First name: Phillip
Last Name: Patton
City: Yoder
I`m just curious.
Coe Franklin
I'm sure you'll love working with the OO. It bends easier than any other wood I've used.
To answer your question, not really. I made the plate a little bigger (if I remember correctly) and made sure it was flatsawn, not quartersawn.
Thanks everybody for your comments! I'm really happy with how this one turned out, though there are still areas that could use improving...
Regards,
Phillip Patton
PostPosted: Sat May 25, 2013 5:31 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Sweet. I love smaller bodied 12 strings. That's some of the nicest osage orange I've seen!!
Very interesting using only 6 bridge pins. Its a much cleaner look
PostPosted: Sat May 25, 2013 5:56 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
I love the boldness of that rosette.
PostPosted: Sat May 25, 2013 10:25 pm
That all works! Very nice looking guitar.
PostPosted: Sat May 25, 2013 11:12 pm
Very nice!
Greg Hatcher
North Carolina
PostPosted: Sat May 25, 2013 11:19 pm
Beautiful work and beautiful guitar.
Is the Ironwood stained, or is that it's natural color?
If the latter, how prevalent or available is this wood? A readily available North American fretboard wood would be something I could get into.
PostPosted: Tue May 28, 2013 10:19 am
First name: Phillip
Last Name: Patton
City: Yoder
That's the natural color. It comes in different flavors. The stuff I used on this guitar is about as plain and straight grained as you can get with DI. It's more common to see it like it is on these two latest knives of mine:
http://www.pattonblades.com/052813-3.jpg
http://www.pattonblades.com/052713-3.jpg
It's a protected species, so you can't harvest live trees anymore. But it's still available, for now...
Regards,
Phillip Patton
PostPosted: Tue May 28, 2013 11:11 am
It's beautiful wood, even the straight grained stuff you're using.
Users browsing this forum: doncaparker and 15 guests
